ReverseYou can reverse the pitch of selected notes (sometimes called invert), thetime of selected notes (sometimes called retrograde), or reverse selected notes ina scale around a note specified as the pivot point. To reverse data:- In the Graphic Editor or Tracks Overview, select the data you want to edit.
- From the Options menu, choose Reverse.
The Reverse dialog box appears.- Choose the options you want (see options list below).
- Click OK.
Reverse editing options:Reverse Pitch - if you want to reverse the pitch of all selected notes, click the Pitch of selected notes button.Reverse Scale - if you want to reverse in a scale, click the In the scale of button and enter the desired key and scale.Reverse Chromatically - you can reverse notes chromatically by clicking this button and enteringthe note to be used as the pivot. Notes on either side of the pivot note willreverse.Reverse Time of Events - if you want to reverse the time of events within a selected area, click the Times of selected events button. The center (in time) of the selection will be the pivot point of thereverse operation. See Also:Changing the Pitch of Notes Pitch Bend |
