| MIDI Machine ControlThis Clock setting allows Metro to send MIDI Machine Control (MMC) commandswhen syncing to SMPTE/MTC. If you have a tape deck or hard disk recorder thatsupports MMC, this setting eliminates the need to start Metro’s transport and then start the sync source. When you hit play in Metro, itwill go into sync mode as above, and it will also start the clock source machine. For more info on the MMC window, see the section in Chapter 11. |
