The Poly After Touch DisplayChoosing Poly After Touch from the Data Type pop-up menu within the current track’s titlebar changes the current track to show Poly After Touch for a specificnote number on that track. Since you are dealing with pitch-specific data, besure to use the Pitch field in the upper portion of the Graphic Editor window to specify the pitch(note) for which you would like to view or edit the Poly After Touch data. Likeother continuous data, Poly After Touch is displayed graphically and can beedited using the Penciland Curve Tools, or selected using the Arrow Tool.See Also:Notes Display - MIDI Piano RollDrums DisplayThe Controller DisplayThe After Touch DisplayThe Tempo DisplayThe Pitch Bend DisplayAverage VelocityThe Program Change Display
