Clicking in column headers will toggle between sorting and reverse sorting that column.
File Area
Files are selected by clicking on them. To select multiple files, hold down either the shift key or the command key while clicking. Shift-clicking selects contiguous files. Command-clicking select non-contiguous files. Ctrl-clicking an item will present a contextual menu providing you with options such as get info, or reveal the file in the finder among other things.
To complete the batch file conversions select the exact type of file format and the file directory. Following that file conversion commences.
Drag items to new locations by clicking and dragging.
Items can dragged to the Graphic Editor where they will be converted to AIFF and then immediately editable.
Items can be dragged to the finder. Files will be moved if they are dragged to a new location. If a file is dragged to the trash it will be removed from the file area and placed in the trash.
If you drag items from the finder to the file area and they are recognized as valid audio files they will be added to the jukebox file list.
Batch File Conversions
As of version 6.2.3 the jukebox's contextual menu, from the file area, contains options for doing batch file conversions. Simply select the items you want to convert and then select one of the following from the jukebox's contextual menu:
- Convert to MP3
- Convert to AIF
- Convert to WAV
- Convert to Quicktime
- Convert to Ogg Vorbis
- Convert Via Quicktime
Options
Directly above the scrollbar is a button with a down pointing arrow. This button is a popup that provides more options, including whether or not the current file list is to continuously play (i.e. overall loop).
Other options are specified in the JukeBox pane of preferences.
Song number
This field display the current song and the number of songs.
Time
The time field toggles between song time, total played time and total play time by clicking on it.
Transport
The individual jukebox transport controls allow you to play, stop, advance to the next and return to the previous song.
Note: It may take some time before the first song starts playing while Metro buffers data, depending on the song's file type.
Note: Pressing any of the transport window's controls will cause the Jukebox to stop playing.
File Popup
From the popup menu, in the upper left of the Jukbox, you can:
- Save file list as: This saves the current file list to the name and location that you specify.
- Select folder: This causes the jukebox to recursively scan the selected folder for audio files. Any folder name that has the word 'disabled' in it will be skipped.
- Add Files From Folder: This causes the jukebox to add files from the selected folder. This differs from the above option in that it does not clear the list before scanning.
- Add New Files From Folder: This is the same as the previous option except that it only adds files that have a newer date than any file currently in the list.
- Below 'Add new Files From Folder' is a list of saved preset file lists and below that is a list of recently visited folders.
