| VST/Paths
Preferences
(Windows Only)
This dialog
allows you to set the path where VST plug-ins are searched for.
In addition to the
user-configurable path, Metro
automatically searches the following path:
on 32 bit operating systems or when running the 64 bit version of Metro:
"X:\Program Files\Steinberg\Vstplugins\"
on 64 bit operating systems when running
the 32 bit version of Metro:
"X:\Program Files
(x86)\Steinberg\Vstplugins\"
where X: is
the drive that Metro was started from, usually C:.
After
startup all available plug-ins can be found in the plug-ins window.
Alternate
audio file search path
This
setting allows you to specify an alternate search path. When a document
is opened that references audio files that cannot be found, this path
will be searched for the missing audio files.
Preferences
Dialog
General
Pane
Buffers
Pane
Movie
Pane
JukeBox
Pane
Buffers
Preferences
