Preferences Saving General, Timers, Buffers, Movie or JukeBox Preferences saves many Metro settings, in addition to those actually listed in therespective Preferences dialog panes.  General Pane Timer Pane Buffers Pane Movie Pane JukeBox Pane Once you enable (or disable) a Metro setting, you must save that setting ifyou want it to remain in effect when you re-open Metro. You save settings byclicking the Save button in any of the Preferences dialog panes. Clicking Save in any of the Preferences dialog panes not only saves all settings listed in that dialog box, but saves most other settings you may have chosen in Metro.
For example, saving any of Metro’s Preferences settings saves many settings chosen from the Setup menu (such as Record Criteria and Record/Play), and most options chosen through Metro doors or dialog boxes. When you restart Metro, the Preferences you saved will be restored. See Also:Setting Record and Play Preferences Saving Preferences |
