Setting Record and Play Preferences
To set Record and Play preferences:
  1. Choose Record/Play from the Setup menu.
The Record and Play Setup dialog box appears.
  1. Select how you want Metro to begin playing and recording:
  1. Choose a Record Loop Setup (you enable loop in the Transport window):
  1. Choose A Record Mode:
    • Choosing Overdub tells Metro to record loop passes onto one track only.
    • Choosing Replace tells Metro to record loop passes onto separate tracks.
    • Choosing Input Quantize opens the Input Quantize dialog box, where you canchoose how you want Metro to quantize notes as you record them. See Quantize under the Options menu for more information about quantizing.
  1. Click OK.
Now that you have set your Record and Play preferences, put them to use in thetutorial, Your First Session with Metro.
