Scale AmplitudeScale AmplitudeThe Scale Amplitude command increases or decreases the amplitude of theselected audio data, but maintains the shape of the waveform.To scale amplitude:- In the Graphic Editor window, select the audio data you want to scale.
- From the Edit menu, choose Audio > Scale Amplitude.
The Scale Amplitude dialog box appears. - In the Change audio to 'N' % of current field, enter a value between 1 and 500. A setting of 100% is neutral which does not change volume level. Settings below 100% decrease amplitude and setting above 100% increase amplitude.
- Click OK.
The amplitude changes, but the shape of the waveform does not change. See Also:Normalize Group Normalize Reverse Fade Cross-Fade Split Stereo TracksCombine Regions |
