Normalize Group Normalize Choose the Normalize command to search through the current audio selection to detect the highest amplitude peak, the volume of the selected audio is then increased by the difference between the detected amplitude peak and the setting entered in the Change audio to N % of maximum field. The Change audio to N % of maximum field accepts values between 1 and 500, a 100% amplitude setting scales the detected amplitude peak to 0 dB (maximum volume without clipping). The overall affect of applying the Normalize command increases perceived loudness across an audio selection. Important: Normalizing by values of more than 100% will produce clipping which may be undesirable. See Also: Reverse Scale Amplitude Fade Cross-Fade Split Stereo Tracks Combine Regions |
