Bypassing Notation (and saving a couple of MBs)
No questions asked!
Postby Jerm » Fri Jul 09, 2004 12:11 pm
:idea: To bypass the notation (and lyrics windows and printing), if you are not going to use it, simply hold the option-key when Metro is starting up.
This has the added benefit of saving approximately 2 MegaBytes of memory under OS X because of the way OS X printing works.
Those megabytes of memory might come in handy, especially if you are using plug-ins (which notoriously leak memory as well).
Postby Scoot » Fri Jul 09, 2004 4:39 pm
does that mean the CPU is taxed less?
or is it more of a case of being loaded, only if the notation is used?
Postby Jerm » Fri Jul 09, 2004 4:59 pm
Well, compared to if the notation window is open and you do a lot of MIDI editing, especially with big MIDI files, it will be much less strain on the cpu.
Otherwise the difference is just memory. When memory gets low OS X starts to choke.
Postby Scoot » Fri Jul 09, 2004 5:04 pm
Doing light things in metro, I can have photoshop golive appleworks mail and safari open quite happily without choking at 768MB.
Maybe my machines too slow to notice.
I do remember going into the mac shop with a friend who was showing me the G5's when they came out and some had 256MB and so many preferences set wrongly that they seemed like a limp dog.
It was not a good way to show off a flagship machine. :?
Postby françois » Mon Feb 14, 2005 4:50 pm
For info my metro folder takes 92,68 Mo ram without holding the option key at the opening, and 87,67 Mo when I hold the option key.
Thanks jerm : 5Mo ram saved.
Could you tell me if it's possible to define a midi buffer for metro application, ( or some priority function ) when it works with other applications ??
I use Audio hi jack pro running with recordins at 24 bits/44khz for long recoding sessions ( 3 / 4 hours ) and at sometimes the counter at the transport window is running very slowly while the music sounds good. But one time metro application began to freeze and a this time metro plays always the same note, and impossible to change that without quit.
Do you know a way to rend osX more light and fast ?
I use for instance my new pb 15" 1,5 Ghz with 512 Mo and will have
soon 1,5 Go.
cheers
François
Postby Jerm » Mon Feb 14, 2005 5:05 pm
I do not know. The only thing I can think of is that your hard disk is getting full. OS X is not friendly when disk space starts getting low.
Postby françois » Mon Feb 14, 2005 11:32 pm
is it possible to prior metro manually to other applications ?
the buffer in the preferences is only for audio, or also for midi ?
my hard is now ok I have 25% free ( 15 to 20Go for the systeme part, and 60 Go to data )
Postby Scoot » Thu Feb 17, 2005 2:51 am
Amazing you're having problems with such a powerful powerbook.
The quickest metro would be running only metro.
Quit the finder - you can do this from inside metro.
Click on DIGITAL AUDIO... in SETUP menu
Goto ADVANCED button and click on little blue car = quits finder
No record tracks ON if not recording
SWITCHES - playback scrolling - OFF
Midi and audio thru OFF if not needed.
SETUP - Chasing... may slow things???.......
The worst thing is using the same drive for everything.
Your best bet is to use a firewire drive and put the audio on it.
BUT from memory you use a firewire audio interface as well.
Does your model PB have 2 firewire ports?
Postby françois » Thu Feb 17, 2005 11:30 am
Scoot wrote:Amazing you're having problems with such a powerful powerbook.
Now it's fine, but on stage I had some troubles....
thanks scoot
I have a partion for the system and another for the data
one 400 port, and one 800 port
Postby Scoot » Thu Feb 17, 2005 10:20 pm
Then you have the ability to get a FW 800 HD and run the audio interface on the 400. :wink:
Return to Tips & Techniques
Users browsing this forum: No registered users and 24 guests
