This has the added benefit of saving approximately 2 MegaBytes of memory under OS X because of the way OS X printing works.
Those megabytes of memory might come in handy, especially if you are using plug-ins (which notoriously leak memory as well).
Scoot wrote:Amazing you're having problems with such a powerful powerbook.
Now it's fine, but on stage I had some troubles....
The quickest metro would be running only metro.
Quit the finder - you can do this from inside metro.
Click on DIGITAL AUDIO... in SETUP menu
Goto ADVANCED button and click on little blue car = quits finder
No record tracks ON if not recording
SWITCHES - playback scrolling - OFF
Midi and audio thru OFF if not needed.
SETUP - Chasing... may slow things???.......
thanks scoot
The worst thing is using the same drive for everything.
Your best bet is to use a firewire drive and put the audio on it.
BUT from memory you use a firewire audio interface as well.
I have a partion for the system and another for the data
Does your model PB have 2 firewire ports?
Users browsing this forum: No registered users and 26 guests
