Sagan Technology Metro • View topic - Scroll Racks with mouse
Postby Vigner » Tue Jan 22, 2013 10:34 am
Hi!!
When i chain my effects in the Effects Synth "rack", i cannot access the ones lastly added.
Jeremy there would be useful if we scrool all the effects in that window.
I dont understand how side chain functions, for what i've reads is very confusing. Could be a better away of using it? More simple to access and use?
I think fades and crossfades in audio editing could be done like others DAWS (using the mouse to control fade curves), as a user mentioned in the forum!!
Can metro interface be more costumized or have new colors or even a change! The interface is so old looking!! But the app is very usefull indeed!! :)
Hope to see more changes in the future!!
Thnx!!
Vigner
Re: Scroll Racks with mouse
Postby Jerm » Tue Jan 22, 2013 4:37 pm
Did you try resizing the effects window?
Postby auwerk » Wed Jan 23, 2013 3:21 am
Vigner wrote:Hi!!
Hello Vigner!
Vigner wrote:Can metro interface be more costumized or have new colors or even a change! The interface is so old looking!!
As for me, I don't like this idea. Why turn everything into colorful "nice" mess? Even if it will make program "modern-looking".
After some time I get used to Metro interface and I like it.
All these "modern-looking" DAWs with huge colored buttons and blinking animated controls are just a waste of screen space and CPU cycles. I use Metro on 13-inch MBP and it fits the screen. That's good! Because it's useful, not because of "inspiring graphics" and all the bells and whistles.
But...
Vigner wrote:Hope to see more changes in the future!!
...me too :)
auwerk
Postby Vigner » Sun Jan 27, 2013 4:24 pm
Yes, i try resizing the window!!
I am not saying to have buttons or images or anything!!
I am just asking to Jeremy create a away o that i can have access to other effets!!
Am i hope to see more improvements!! Maybe more ways to work with midi, like rythm explorer!! :)
Vigner
Postby Jerm » Sun Jan 27, 2013 6:13 pm
I don't understand. You have access to everything. If you resize the window you should be able to see all of the plug-ins instantiated. If not please post or email me a picture of the problem.
Alternatively you can access ALL plug-ins in a chain via the graphic editor or track window popups. Simply select the plug-in (with a check mark) from the popup menu to edit them. Also you can add plug-ins to the chain with the popup menus too, simply hold the shift-key and select a new plug-in from the menu. The shift-key will add the plug-in to the end of the chain.
Postby Vigner » Mon Jan 28, 2013 5:50 pm
Ah there another way to do what i wanted!!
Thnx for the info!!
But i will send a picture to let you know what i am talking about!
Can you send me your contact, please?
Vigner
Postby Jerm » Mon Jan 28, 2013 5:56 pm
send email to info 'at' sagantech.biz
Users browsing this forum: Google [Bot] and 1 guest
