Sagan Technology Metro • View topic - Metro 6.22 vs KORG KONTROL49
Postby Territan » Sat Jun 04, 2005 2:24 pm
(I swear, that name is so Bauhaus...)
Here's the situation: I went out and bought myself a fancy MIDI controller -- a fancy word for a keyboard that doesn't actually do anything by itself. It works well with Reason, but I can't get it to recognize in Metro.
I know there's a way to do this, too, such that anything I hit on the KONTROL49 is actually played by Metro in the selected instrument. I've actually been able to do this before, long ago, and now I don't remember how.
Can anyone tell me what horrendously obvious thing I'm missing?
The computer, by the way, is a 1.67GHz Powerbook G4 fully loaded, so let's assume massive latency isn't a problem.
Territan
Re: Metro 6.22 vs KORG KONTROL49
Postby Jerm » Sat Jun 04, 2005 4:18 pm
Territan wrote:I know there's a way to do this, too, such that anything I hit on the KONTROL49 is actually played by Metro in the selected instrument. I've actually been able to do this before, long ago, and now I don't remember how.
First make sure in the MIDI setup dialog you have the KONTROL49 selected from the 'record from' popup.
If you do not see KONTROL49 then you need to re-configure your Audio MIDI setup dialog.
Then in the switches menu make sure there is a check mark next to 'Automatic MIDI thru'. Now when you record-enable a track MIDI thru will follow to the record-enabled-track's output.
Territan wrote:The computer, by the way, is a 1.67GHz Powerbook G4 fully loaded, so let's assume massive latency isn't a problem.
You can change the latency in the device-option dialog. This dialog is located in the audio setup dialog accessed from the setup menu or by typing ctrl-A.
Postby Adrian Delso » Mon Jun 06, 2005 3:00 am
Jerm,
This is only with the full version of Metro, right?
Adrian Delso
Postby Jerm » Mon Jun 06, 2005 8:14 am
Adrian Delso wrote:Jerm,
No, the previous instructions should work with all Metro versions including SE and LX.
Postby cornutt » Wed Jun 08, 2005 9:23 pm
Also, you might want to go look under "Record Criteria..." (Special menu) and make sure all of the MIDI data types you want are checked. Otherwise, you might find that notes work, but the knobs and buttons don't. In particular, if I remember right, System Exclusive is not checked in the as-shipped defaults.
cornutt
