| Applying Effects Offline Applying Effects Offline There is a known problem in the OS X version of Metro 6.0 regarding the Plug In Effects Processor. Please visit the downloads page for a free upgrade to 6.0.1 or later. Adding effects offline preserves your computer’s processing capacity. To keep your original audio data intact and readilyaccessible, it’s a good idea to copy your audio track and apply effects to the copy. To apply effects offline:- Select a track or region in a track to add an effect to.
- From the Edit menu, choose Audio and select an effect from the submenu.
The Plug In Effects Processor dialog box appears.- Click the Preview button to hear a preview of your track with the selectedeffect.
- If you like the effect, click OK. Otherwise, click Cancel and select anothereffect.
See Also:Effects Tutorial Adding Real-time Effects to One Track Adding Real-time Effects to Multiple Tracks Adding Effects in Real-time Metro's Effects |
