Revolutions get lost when expanding pattern in RevArp
Postby Lytz1 » Fri Nov 02, 2018 8:18 pm
So here's another one:
When I have set up some revolutions in the Revo-Arp
and then do "expand pattern", they get all lost. (All degrees reset to "1" and loose
the "movement")
That's not so good.
Also: When using "Randomize Rhythm" all "C" settings get lost.
(Everything resets to "--" instead of 1+3, chord, etc...)
That's also not so good.
Re: Revolutions get lost when expanding pattern in RevArp
Postby Jerm » Sat Nov 03, 2018 12:52 pm
Lytz1 wrote:do "expand pattern", they get all lost.
When I tried it the pattern was expanded and each time a 'revolution' step was hit, the pitch was recalculated based on the revolution data. This seems like the correct approach as if you just expanded the revolution data you would get different results that the original.
Lytz1 wrote:Also: When using "Randomize Rhythm" all "C" settings get lost.
This was a bug that is now fixed. It also affects Randomize.
Postby Lytz1 » Tue Nov 06, 2018 12:26 pm
Yes, you're right. Don't know how I missed that.
Awesome. Yeah, now I remember something odd was going on with randomizing as well.
At the time I thought this was the usual behavior of the randomize function.
That's why I didn't use it for quite some time now.
Users browsing this forum: No registered users and 20 guests
