XML files
XML files
Postby w » Sat Mar 18, 2017 10:59 pm
Can Metro open XML files/documents ?
And if so , how ?
w
Re: XML files
Postby Jerm » Sun Mar 19, 2017 4:44 pm
I don't know what it would do if it opened it. Is there a reason to open .XML files?
Re: XML files
Postby GSpro » Sun Mar 19, 2017 6:48 pm
Hi,
I think, w is referring to the importing of Musicxml which, is way better than just importing a MIDI file.
An exported MIDI file, only contains patches, notes, tempo, note length, volumes and a few other things.
XML contains everything from a MIDI file and alot more info, like : clefs, lines per page, measure per line, dynamic marks, articulations, lyrics, text, slurs, stem direction, tablature, repeat signs, endings and on and on.
Many DAW and scoring apps have implemented Import/Export of .XML.
Is this what you meant, w?
GSpro
Re: XML files
Postby w » Sun Mar 19, 2017 7:19 pm
I have several Mac DAW's that make use of XML files including PG music Band in a Box .
Perhaps XML files would help with Metro's notation because i have noticed some disparities using imported midi files.
for reference : http://www.musicxml.com/tutorial/faq/
w
Re: XML files
Postby w » Sun Mar 19, 2017 7:22 pm
GSpro"
Exactly correct.
Which is why i was surprised to discover Metro does not have that feature. Yet?
w
Re: XML files
Postby GSpro » Sun Mar 19, 2017 7:28 pm
w wrote:GSpro"
Exactly correct.
Yes XML Import/Export will be a big plus. What would be nice is to update the score in Metro with more features to export to xml and then re-import into Finale, Sibelius or, Notion to refine and for better layout.
GSpro
Re: XML files
Postby w » Sun Mar 19, 2017 8:47 pm
Fully agree.
The notation in Metro needs a huge improvement in the first place and if Jerm could implement XML that would indeed be plus factor.
w
Re: XML files
Postby w » Sat Mar 17, 2018 11:06 pm
When will Mac Metro ( current version ) be able to import XML ?
w
