Jim Obermeyer wrote:I just bought a Alesis QS8.2 and I have an iMac Os X running on 10.2.8 with your 6.1 demo on it. I looking at buying a M-Audio USB Uno 1X1 MIDI Interface. Do you think these items will work well together.
Of course you should purchase Metro 6.4.x as 6.1 is a very old version now.
Jerm wrote:Hello Jim,
Usually this happens if you are sending track 2 to the same MIDI Channel as track 1 or the MIDI device is not in multi-timbral mode.
To solve the first possibility be sure that track one's output is 'Alesis - 1' and track two's output is assigned to 'Alesis - 2'. This setup can be configured in the tracks window popup.
To set the Alesis to multitimbral mode please check its user manual.
If this is not clear or you get stuck at any point please post here again.
Jim Obermeyer wrote:I lined up track one's output which say USB Uno MIDI-1 (not Alesis - 1) and I also set my Alesis MIDI channel to one also.
Jim Obermeyer wrote:...
I checked my owners manuel for the Alesis and it just says the instrument is multitimbral but I can't find any mode selection.
Users browsing this forum: No registered users and 68 guests
