Maybe this could be a feature request?
Here's a tutorial about the sidechain compressor: http://sonictransfer.com/side-chain-com ... rial.shtml
Sidechain compressing is cool...
I have been researching this issue and I am confident sidechaining will be implemented in Metro 6.4.
Paul wrote:Any idea when 6.4 will be released?
It sounds like you may need to use them.Paul wrote:Could you name a situation in which it would come in handy to use an aux-bus?
To the input of the compressor anyway and post fader/effects.Paul wrote:Suppose that I have a kick drum on track 1 and a bassline on track 2 and I use a sidechain compressor on track 2, with track 1 supplying the sidechain signal. Will the entire signal from track 1 be sent to track 2?
In this case the kick drum's output fader will control both the amount sent to the side chain and the final output but you can get around that by sending the kick drum track to a dummy aux buss pre-fader and then using the aux buss as a source for the compressor. Of course then the compressor must also be placed on a second aux buss.Paul wrote: In other words, will it only be used to influence track 2 and won't the kick drum itself be heard at all?
Yes. It might be better to have the sidechains pre-fader or selectable pre/post fader but this requires substantially more work.Paul wrote:However, when the signal from track 1 is still being heard, then I think it's a problem, because altering the volume of that track will also mean altering the amount of compression.
No because it is not a track output. It is related to the effects input. Right now in 6.4 you need to right (or ctrl) click on the effects title bar which brings up a contextual menu that lets you select any of the effects inputs as a sidechain input. If the effect had 4 inputs there would be a second menu item named '3+4' and it would have a submenu with tracks and auxes attached. Here is a picture:Paul wrote:I am not sure how you plan to implement it, but I think I will just have to choose the input of the sidechain compressor as the output for track 1 in the outputs column?
Users browsing this forum: No registered users and 43 guests
