Can't help, but I can commiserate. I get the same results on my lowly G4/500. Plus, I've found some SC-8850.ins files (I found a number doing a Google search) don't display properly in the drop-down menu pane once they've been imported. The pane simply doesn't appear, and I sort of have to "mouse around blind", hoping that I'll magically pick the right bank definition on the invisible list (if that makes any sense). And, like you, I have not been able to get these settings to stick from session to session, anyway. Kind of a showstopper for those of us w/ non-GM modules.buserror wrote:Trying to import the SC-8850.ins takes 15 minutes. FIFTEEN MINUTES on a dual Ghz machine, with 1.5Gb memory.
What is it doing? The CPU is idling, and the progress bar is crawling.
Not only that, but it's not saved as a global setting, and I ALSO have to re-import it for the 'B' channels.
Jerm wrote:For program name files to be persistent, one needs to:
a) make sure they have at least SE version 6.0.3
b) save preferences after importing any .ins files.
We will take a look to see why the import is so slow. Please point me to the .ins file.
Jeremy
buserror wrote:<snip>I suspect the loop was too busy drawing the progress bar to get any proper work done. It's rather typical of carbon<snip>
Is the "invisible popup window" fixed too? I had that several times as well.
<snip>
This is exactly the problem I had. I believe it was 100% reproducible (for me), given the same .ins file. I found a number of SC-8850 instrument definition files on the web, and I think at least one of them did not display this behavior. Unfortunately, they're all named either SC-8850.ins or roland.ins, so I can't remember which is which at this point.buserror wrote:Well, after having waited the 15 minutes required to import the SC-8850 file, most of the time (but not always) clicking the popup to see the bank would do nothing.
However, clicking, draging and releasing the mouse WOULD change the selected bank name to somthing else, kinda like the popup window was there, but invisible.
It is not reproducible 100%, sorry
I did figure that one out, but it certainly strikes me as poor UI design - at some point you may want to really overhaul this panel, but just reversing the "read order" of the two menus would surely help.Jeremy wrote:I do not know if this is related or not but you should definitely select the port that you want the .ins file assigned to before importing.
Users browsing this forum: No registered users and 12 guests
