Virus TI
Virus TI
Postby Paul » Fri Dec 29, 2006 5:54 am
Bought myself a virus TI and having some problems with the VirusControl plugin. There is a latency when playing back through the TI's USB port. When using a 'normal' plugin, there's no latency. Is there something I should change in Metro's (6.3.8.1) settings or is this a known problem? I don't have this problem when using Logic.
Paul
Postby Jerm » Fri Dec 29, 2006 12:15 pm
Try going to audio Setup:device options and modifying the audio packet size (e.g. make it smaller).
Postby Paul » Mon Jan 01, 2007 8:44 am
I set it to 128, but there's still latency when playing back. Are there any other people out there who work with Metro and the Virus TI that have the same problem?
Paul
Postby Jerm » Mon Jan 01, 2007 3:36 pm
Well if that does not fix it I do not know what it is. I have contacted Access directly and can only wait for a response. The only way I would be able to resolve this would be if I had a T1 unit in house.
Postby Scoot » Tue Jan 02, 2007 11:45 pm
Can this situation be cured by the offset options in
Setup Menu/Digital Audio Setup/Advanced
If the virus device is lagging, the time can be measured in samples against other tracks and you can input the amount in the dialog.
Postby Jerm » Wed Jan 03, 2007 12:56 am
Support from Access-Music said they might have a chance to look into this further after the January NAMM show.
Postby Paul » Fri Mar 02, 2007 4:00 pm
Hi Jerm,
any word from Access yet about this problem?
Paul
Postby Jerm » Fri Mar 02, 2007 4:23 pm
Well I recontacted them and am now awaiting a response. They, for obvious reasons, are not willing to swap NFR's of hardware for software so I asked for a loaner if they cannot spend the time to look into this probelm on their end.
Postby Paul » Sun Mar 04, 2007 6:52 am
That's too bad. Hope you can solve the issue. In the meantime I'll just use midi instead of usb for playback. I can still transfer the audio signal using usb and then manually place the audio region in sync. Not really 'Total Integration', but at least partial... :)
Paul
Postby Jerm » Mon Apr 02, 2007 4:55 pm
It looks like they are finally going to send me a loaner so I will be able to check this problem out.
Postby Paul » Tue Apr 03, 2007 12:35 pm
Cool... I got a MacBook recently and installed Metro. Problem occurs with that configuration as well. Hope you can find the problem.
Paul
Postby Jerm » Tue Apr 03, 2007 12:52 pm
Hello Paul,
How do you like the T1 otherwise? I have heard good things about it.
Postby Paul » Wed Apr 04, 2007 1:16 pm
Well, the sound of the Virus is a matter of taste. I've always loved the digital kind of sound it produces. I also like the new hypersaw and wavetable oscillators but I don't care that much for the somewhat weird sounds the graintable and formant-based oscillators produce. I guess they're not for me.
It's also great to be able to use it together with the Virus Control plug-in from within my DAW. It's true that you forget that you're working with a hardware synth. I must say though that the only program I've got it working with without problems is Logic. Ableton Live (serious arp sync problems and then some...) and Metro (sorry dude...) don't seem to like it that much. I'm sure that once you get the loaner, I won't have to resort to Logic anymore... 8)
Paul
Postby Jerm » Tue Apr 10, 2007 4:53 pm
Well I got the Virus TI loaner and it seems to work as I expected it would. There is latency compensation being applied but it only works properly if the TI plug-in is placed as a track insert. If the TI plug-in is placed on an aux buss there will be a 4k sample latency which, of course, makes it pretty much unusable for real time stuff. Have you tried it with the TI as a track insert?
I am still just getting started checking it out and I am running on an Intel mac so there may be more serious problems.
Postby Paul » Wed Apr 11, 2007 10:06 am
Hi Jerm, forgive me... but exactly how do I insert the Virus Control as a track insert? The two ways I've tried: using the plugs pop-menu in the track list and dragging the plugin from the plug-ins window to the effects/synths window. Either method produces the mentioned issue. Can you tell me how you did it?
Paul
Users browsing this forum: No registered users and 27 guests
