Tempo
Tempo
Postby françois » Sat Sep 24, 2005 10:57 pm
Hello,
All my tempo's variations are disabled.
it's certanely my fault.
Could you tell me how to enable again this function please ?
Postby Scoot » Sun Sep 25, 2005 4:19 am
SETUP menu - Record Criteria - tick the box for tempo changes?
Postby françois » Sun Sep 25, 2005 4:25 am
Yes it was the only dismatch....
thanks you save my session this afternoon.
I don't remind to go to " record "
thanks again
François
Don't Works
Postby françois » Sun Sep 25, 2005 4:33 am
Sorry, but I tried with record Criteria, but it don't works.
I have to relaunch the song to succeed the tempo changes, it's not good at the first time....
Postby françois » Sun Sep 25, 2005 5:02 am
I found the reason why....
The folders saved without my plug-in "stylus RMX " have the good tempo changes, but since I work with this plug I must have done something wrong.
but I don't know what for instance...
Postby Scoot » Sun Sep 25, 2005 5:06 am
If you have a midi track running at 120bpm select an area like bars 3 to 6 and then change the tempo on the transport window to say 150bpm.
then the track will go
120 bpm 1-2
150 bpm 3-6
120 bpm 7-onward.
Postby Scoot » Sun Sep 25, 2005 5:09 am
françois wrote:I found the reason why....
Is the stylus plugin driving the tempo?
That could be the problem.
If stylus is running samples at a certain speed, stylus is overriding the metro 'tempo'.
Postby françois » Sun Sep 25, 2005 5:23 am
In fact stylus is just running in one song for instance.
And my song's tempo are good ( but without any changement...)
Postby Jerm » Sun Sep 25, 2005 10:22 am
Did you go to the section event editor and see if there are multiple tempo changes?
Postby françois » Fri Dec 02, 2005 7:29 am
how can I change the global tempo when there is multiple tempo changes in a song ?
I want to reduce the song's tempo, but if I change the tempo, all the multiple tempos changes are erased, and only the defined tempo remains.
Postby Jerm » Fri Dec 02, 2005 8:48 am
You could use the slider in the transport to scale all of the songs tempo changes.
Users browsing this forum: No registered users and 90 guests
