save and restore cues
Postby cruzin » Wed Feb 23, 2005 10:26 pm
I use a sequencer as a practice tool. Once I get the song entered I use the computer as a "music minus one" machine so I can practice my part. Usually there are sections of the piece that are more difficult, so I like to loop these to practice them.
I need to be able to set up multiple sections for looping. Not just looping a single track, but the whole piece, all tracks. Cues work nicely for this except for 3 things:
1) I am limited to 4 cues
2) The cue start/stop cannot be edited -- I am limited to using the mouse to set start and stop
3) cues are not saved or restored with the project.
Note that I tried doing this with loops but found that it didn't work nearly as easily as cues. (In fact it didn't work well at all).
It would be great if the 3 things above could be addressed in the next software release.
thanks
cruzin
Postby Jerm » Sun Feb 27, 2005 10:04 am
I am not sure I understand number 2. If you have LX or the full version you can use set selection to set the cue. Is this the kind of thing you are talking about?
Postby cruzin » Sun Feb 27, 2005 12:32 pm
I have SE.
Maybe this will make it clearer:
If you set a marker, the initial time of the marker is set from the selection. But you get a pop up where you can enter the measure/beat/tick. You can also click on the marker at any time and change the measure/beat/tick by typing in new values.
Cues can only be set from the selection. It would be nice to have a way to "edit cue" where a pop up lets you type in the start and stop times.
cruzin
Re: save and restore cues
Postby Jerm » Thu Mar 24, 2005 11:45 pm
cruzin wrote:3) cues are not saved or restored with the project.
This required a database change but is implemented in 6.2.7, which will be the next pre-release. This also required having cues dependent on the section. This means that you get 4 independent cues with each section or subsection.
Postby cruzin » Fri Mar 25, 2005 2:00 am
sounds great. thanks.
cruzin
Users browsing this forum: No registered users and 45 guests
