metro 6.22 spray can in graphic editor drums crash
Postby niro » Sat Nov 06, 2004 5:12 pm
Notes:
metro v6.22, powerbook g4 / powermac g4, osx 10.3.5, 10.3.6, pluggo, other vsti's.
Repro steps:
1. load any vsti (drag from Plug-Ins window to Effects/Synths window)
2. switch to graphic editor [keystroke command+j], drums [keystroke d]
3. click the spray can tool
4. spray and crash
I can send a console log if you want to send me a debug build, however the crash is pretty straightforward. I didn't try it on os9 yet.
niro
Postby Jerm » Sat Nov 06, 2004 6:13 pm
Please send the log. I cannot reproduce this. Can you give a more specific VSTi? Have you tried trashing preferences?
Postby Scoot » Sat Nov 06, 2004 6:13 pm
You don't have to add a plugin to make it happen.
Happens in 6.2.2 and 6.2.1.7 the only 2 metro versions I have......so it wasn't the last update that caused it.
Postby Jerm » Sat Nov 06, 2004 6:16 pm
Perhaps it is your spray can settings. A picture or a list of spray can settings in the spray can dialog would help.
What is the drum set that you see in when you switch to drum mode?
Postby Scoot » Sat Nov 06, 2004 6:27 pm
Postby Jerm » Sat Nov 06, 2004 9:50 pm
I still cannot reproduce any problem. :?
Postby Scoot » Sat Nov 06, 2004 9:53 pm
Jerm wrote:I still cannot reproduce any problem. :?
I've heard that before. I want your computer. :)
Postby niro » Sat Nov 06, 2004 11:48 pm
Here's a log using pluggo:
Date/Time: 2004-11-06 20:45:35 -0800
OS Version: 10.3.6 (Build 7R28)
Report Version: 2
Command: Metro G4
Path: /Applications/Metro-G4-6.22/Metro G4.app/Contents/MacOS/Metro G4
Version: 6.2.2 (6.0)
PID: 257
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000022
Thread 0 Crashed:
0 biz.sagantech.Metro 0x000c8de8 __code_start__ + 0xc5028
1 biz.sagantech.Metro 0x000c882c __code_start__ + 0xc4a6c
2 biz.sagantech.Metro 0x000916d8 __code_start__ + 0x8d918
3 biz.sagantech.Metro 0x00090d94 __code_start__ + 0x8cfd4
4 biz.sagantech.Metro 0x00090b48 __code_start__ + 0x8cd88
5 biz.sagantech.Metro 0x00090be4 __code_start__ + 0x8ce24
6 biz.sagantech.Metro 0x0008fafc __code_start__ + 0x8bd3c
7 biz.sagantech.Metro 0x00003f70 __code_start__ + 0x1b0
8 biz.sagantech.Metro 0x00003df0 __code_start__ + 0x30
Thread 1:
0 libSystem.B.dylib 0x90018be8 semaphore_timedwait_signal_trap + 0x8
1 libSystem.B.dylib 0x9000e788 _pthread_cond_wait + 0x268
2 ...ple.CoreServices.CarbonCore 0x902aa798 TSWaitOnSemaphoreCommon + 0xb0
3 ...ple.CoreServices.CarbonCore 0x902be6e8 TimerThread + 0x3c
4 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 2:
0 libSystem.B.dylib 0x900074c8 mach_msg_trap + 0x8
1 libSystem.B.dylib 0x90007018 mach_msg + 0x38
2 com.apple.audio.midi.CoreMIDI 0x81ebdc9c XServerMachPort::ReceiveMessage(int&, void*, int&) + 0x54
3 com.apple.audio.midi.CoreMIDI 0x81eb0d58 MIDIInPortThread::Run() + 0x13c
4 com.apple.audio.midi.CoreMIDI 0x81eb4e50 XThread::RunHelper(void*) + 0x3c
5 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 3:
0 libSystem.B.dylib 0x90054068 semaphore_timedwait_trap + 0x8
1 biz.sagantech.Metro 0x000a3f78 __code_start__ + 0xa01b8
2 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 4:
2 com.apple.audio.CoreAudio 0x907244fc CAGuard::WaitFor(unsigned long long) + 0xdc
3 com.apple.audio.CoreAudio 0x90724130 CAGuard::WaitUntil(unsigned long long) + 0x130
4 com.apple.audio.CoreAudio 0x90722b20 HPIOThread::WorkLoop() + 0x358
5 com.apple.audio.CoreAudio 0x9073919c HPIOThread::ThreadEntry(HPIOThread*) + 0x1c
6 com.apple.audio.CoreAudio 0x907391e0 CAPThread::Entry(CAPThread*) + 0x30
7 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
PPC Thread State:
srr0: 0x000c8de8 srr1: 0x0200f030 vrsave: 0x00000000
cr: 0x44000284 xer: 0x00000000 lr: 0x000c8db0 ctr: 0x90281234
r0: 0x051bb62c r1: 0xbffffb30 r2: 0x006c540a r3: 0xbffffbc0
r4: 0x00006768 r5: 0x00000000 r6: 0xbffffac4 r7: 0xbffffac0
r8: 0x00070007 r9: 0x72f00000 r10: 0x9028ac6c r11: 0xa1560194
r12: 0x90281234 r13: 0x00308b9c r14: 0x000c8b9c r15: 0x00000000
r16: 0x00000180 r17: 0x00000180 r18: 0x00000000 r19: 0x00000000
r20: 0x00000000 r21: 0x00000000 r22: 0x00000006 r23: 0x00000301
r24: 0x0030a208 r25: 0x0030a19c r26: 0x00249878 r27: 0x002495c6
r28: 0x00309b98 r29: 0x00000305 r30: 0x00000118 r31: 0x00248b9c
Binary Images Description:
0x1000 - 0x248fff biz.sagantech.Metro 6.2.2 (6.0) /Applications/Metro-G4-6.22/Metro G4.app/Contents/MacOS/Metro G4
0x7ff000 - 0x7ff82b plugmidiinˠ PEF binary: plugmidiinˠ
0x17fe000 - 0x17fee7e plugout~?¨¿ PEF binary: plugout~?¨¿
0x1955600 - 0x19575f3 PlugInFragZ– PEF binary: PlugInFragZ–
0x49cd000 - 0x49d7fff com.echoaudio.plugin.Echo24 1.3.0 /System/Library/Extensions/Echo24PropertyPlugin.bundle/Contents/MacOS/Echo24PropertyPlugin
0x49dd000 - 0x49ddfff com.apple.aoa.halplugin 2.4.1 /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x4a44000 - 0x4a80fff com.apple.iSightAudio 6.5.2 /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin/Contents/MacOS/iSightAudio
0x4bbe000 - 0x4bd7f9b <Unknown disk fragment> PEF binary: <Unknown disk fragment>
0x4bd8000 - 0x4bdfe83 MaxAudioLib PEF binary: MaxAudioLib
0x4be0000 - 0x4be7833 OpenGLLibrarypwpc PEF binary: OpenGLLibrarypwpc
0x4be7840 - 0x4be826b OpenGLUtilitypwpc PEF binary: OpenGLUtilitypwpc
0x4bf2000 - 0x4bf4f6f hint PEF binary: hint
0x4bf5000 - 0x4bf763a meter~ PEF binary: meter~
0x4bf8000 - 0x4bfa83a pp5{ PEF binary: pp5{
0x4bfb000 - 0x4bfca9a incdec PEF binary: incdec
0x4bfe000 - 0x4bff26e bondo PEF binary: bondo
0x4c04590 - 0x4c04642 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0x4c04830 - 0x4c048e5 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
0x4c262b0 - 0x4c26341 CFMPriv_AGL PEF binary: CFMPriv_AGL
0x4c26e00 - 0x4c26ea3 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
0x4c26f10 - 0x4c26f87 CFMPriv_System PEF binary: CFMPriv_System
0x4c27200 - 0x4c272d0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0x4c27340 - 0x4c27413 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0x4c274e0 - 0x4c2759b CFMPriv_Help PEF binary: CFMPriv_Help
0x4c275a0 - 0x4c2766a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0x4c276e0 - 0x4c277b6 CFMPriv_HTMLRendering¬qê¬r‡ PEF binary: CFMPriv_HTMLRendering¬qê¬r‡
0x4c27820 - 0x4c278f3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0x4c27970 - 0x4c27a55 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0x4c27ac0 - 0x4c27b96 CFMPriv_OpenScripting?MacBLib PEF binary: CFMPriv_OpenScripting?MacBLib
0x4c27c60 - 0x4c27d1e CFMPriv_Print PEF binary: CFMPriv_Print
0x4c27d30 - 0x4c27dfd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0x4c27e70 - 0x4c27f52 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0x4c27fc0 - 0x4c28093 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0x4c28100 - 0x4c281d3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0x4c282a0 - 0x4c28362 CFMPriv_AE PEF binary: CFMPriv_AE
0x4c28370 - 0x4c28435 CFMPriv_ATS PEF binary: CFMPriv_ATS
0x4c284a0 - 0x4c28577 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0x4c285f0 - 0x4c286d3 CFMPriv_FindByContent¬vp¬Ä† PEF binary: CFMPriv_FindByContent¬vp¬Ä†
0x4c28740 - 0x4c2881a CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0x4c28880 - 0x4c28960 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0x4c289e0 - 0x4c28ac6 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0x4c28b90 - 0x4c28c67 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0x4c28c70 - 0x4c28d32 CFMPriv_QD PEF binary: CFMPriv_QD
0x4c28e20 - 0x4c28f09 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0x4d05000 - 0x4d509b1 CarbonLibpwpc PEF binary: CarbonLibpwpc
0x4d509c0 - 0x4d68cad Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
0x4d6c000 - 0x4e8aa9b MaxPPC3.1 PEF binary: MaxPPC3.1
0x50a8000 - 0x50a9fff com.cycling74.maxaudioapi.framework MaxAudioAPI version 1.0 (1.0) /Library/Frameworks/MaxAudioAPI.framework/MaxAudioAPI
0x50ee000 - 0x50f236e fpic PEF binary: fpic
0x5113000 - 0x5119290 pictslider8ê PEF binary: pictslider8ê
0x511a000 - 0x511b9bd plugmultiparam PEF binary: plugmultiparam
0x511c000 - 0x511ca82 split PEF binary: split
0x511d000 - 0x511d5b9 mtof PEF binary: mtof
0x51a1000 - 0x51a68ac plugconfig PEF binary: plugconfig
0x51a7000 - 0x51ad3a2 coll PEF binary: coll
0x51ae000 - 0x51b399d poly~ PEF binary: poly~
0x51b4000 - 0x51b4b6a clip PEF binary: clip
0x51b5000 - 0x51bafa2 pictctrl PEF binary: pictctrl
0x51bc000 - 0x51bd01a vexpr PEF binary: vexpr
0x51be000 - 0x51bebcd prepend PEF binary: prepend
0x51bf000 - 0x51bfbad inóª PEF binary: inóª
0x51c0000 - 0x51c0a4f thispoly~?p PEF binary: thispoly~?p
0x51c1000 - 0x51c1f94 clip~ PEF binary: clip~
0x51c2000 - 0x51c2b58 *~5{ PEF binary: *~5{
0x51c3000 - 0x51c3686 sig~ PEF binary: sig~
0x51c4000 - 0x51c5365 out~ PEF binary: out~
0x51c6000 - 0x51c7aa5 cycle~ PEF binary: cycle~
0x51c8000 - 0x51c8ae0 +~ç[ PEF binary: +~ç[
0x51c9000 - 0x51ca990 sprintf PEF binary: sprintf
0x51cb000 - 0x51cc3c5 curve~ PEF binary: curve~
0x51cd000 - 0x51cdb9d onepole~ƒ?@ PEF binary: onepole~ƒ?@
0x51ce000 - 0x51ce5d2 noise~ PEF binary: noise~
0x5251000 - 0x525da3f lcd{ PEF binary: lcd{
0x5289000 - 0x528f3b1 umenu PEF binary: umenu
0x52fd000 - 0x52fedd4 fffb~ PEF binary: fffb~
0x52ff000 - 0x52ff8d9 overdrive~ PEF binary: overdrive~
0x5316000 - 0x5317c3c dac~ PEF binary: dac~
0x5318000 - 0x5322cf4 buffer~ PEF binary: buffer~
0x79430000 - 0x794f4fff com.apple.QuickTime3GPP.component 6.5.2 /System/Library/QuickTime/QuickTime3GPP.component/Contents/MacOS/QuickTime3GPP
0x81eb0000 - 0x81eeefff com.apple.audio.midi.CoreMIDI 1.4 (29) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x88e60000 - 0x88e6cfff com.apple.agl 2.5 (AGL-2.5) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x8b0c0000 - 0x8b788fff com.apple.QuickTimeComponents.component 6.5.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x8be30000 - 0x8be31fff DVComponentGlue /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x8c390000 - 0x8c3d1fff com.apple.QuickTimeFirewireDV.component 6.5.2 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFirewireDV
0x8e990000 - 0x8ea21fff com.apple.QuickTimeMPEG4.component 6.5.2 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x8fe00000 - 0x8fe4ffff dyld /usr/lib/dyld
0x90000000 - 0x90122fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90190000 - 0x9023dfff com.apple.CoreFoundation 6.3.5 (299.32) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90280000 - 0x904f9fff com.apple.CoreServices.CarbonCore 10.3.6 (10.3.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90570000 - 0x905dffff com.apple.framework.IOKit 1.3.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90610000 - 0x9069afff com.apple.CoreServices.OSServices 3.0.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90700000 - 0x90700fff com.apple.CoreServices 10.3 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90720000 - 0x90787fff com.apple.audio.CoreAudio 2.1.2 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x907f0000 - 0x907f9fff com.apple.DiskArbitration 2.0.4 /System/Library/PrivateFrameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x90810000 - 0x90810fff com.apple.ApplicationServices 1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90830000 - 0x9089ffff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90910000 - 0x90983fff com.apple.DesktopServices 1.2.2 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x909f0000 - 0x90b4bfff com.apple.Foundation 6.3.5 (500.56) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90c30000 - 0x90c4afff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90c60000 - 0x90cc2fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x90d00000 - 0x90d1bfff com.apple.SystemConfiguration 1.7.1 (???) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90d40000 - 0x90d40fff com.apple.Carbon 10.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90d60000 - 0x90d6bfff com.apple.opengl 1.3.6 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x910b0000 - 0x91101fff com.apple.bom 1.2.5 (63.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x912a0000 - 0x912bdfff com.apple.audio.SoundManager 3.8 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x912e0000 - 0x912f7fff com.apple.LangAnalysis 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91320000 - 0x913defff ColorSync /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91460000 - 0x91473fff com.apple.speech.synthesis.framework 3.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x914a0000 - 0x91509fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x91560000 - 0x91619fff com.apple.QD 3.4.65 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91670000 - 0x916a8fff com.apple.AE 1.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x916e0000 - 0x91773fff com.apple.print.framework.PrintCore 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x917e0000 - 0x917f0fff com.apple.speech.recognition.framework 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91810000 - 0x9182afff com.apple.openscripting 1.2.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91850000 - 0x91860fff com.apple.ImageCapture 2.1.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x91890000 - 0x9189cfff com.apple.help 1.0.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x918c0000 - 0x918cdfff com.apple.CommonPanels 1.2.1 (1.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x918f0000 - 0x9193efff com.apple.print.framework.Print 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x91990000 - 0x9199bfff com.apple.securityhi 1.2 (90) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x919c0000 - 0x91a33fff com.apple.NavigationServices 3.3.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91a90000 - 0x91a90fff com.apple.audio.units.AudioUnit 1.3.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x91ab0000 - 0x91ac4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x91ae0000 - 0x91aebfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x91b10000 - 0x91b2afff libPDFRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPDFRIP.A.dylib
0x91b50000 - 0x91b5ffff libPSRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPSRIP.A.dylib
0x91b80000 - 0x91b93fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91bb0000 - 0x91d45fff com.apple.QuickTime 6.5.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92070000 - 0x92096fff com.apple.FindByContent 1.4 (1.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x920c0000 - 0x922a7fff com.apple.security 2.4 (177) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92430000 - 0x92468fff com.apple.LaunchServices 10.3.5 (98.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92740000 - 0x92777fff com.apple.CFNetwork 1.2.1 (7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x927d0000 - 0x92b54fff com.apple.HIToolbox 1.3.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92d30000 - 0x92d80fff com.apple.HIServices 1.4.1 (0.0.1d1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x935d0000 - 0x938a8fff com.apple.CoreGraphics 1.203.26 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x939a0000 - 0x939b4fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x939d0000 - 0x939d4fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x93b50000 - 0x93bf3fff com.apple.audio.toolbox.AudioToolbox 1.3.2 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x94060000 - 0x94078fff com.apple.WebServices 1.1.1 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x945b0000 - 0x945b9fff libz.1.dylib /usr/lib/libz.1.dylib
0x94610000 - 0x9462afff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x94650000 - 0x946affff com.apple.SearchKit 1.0.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94a30000 - 0x94af5fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x94b20000 - 0x94badfff com.apple.ink.framework 101.1.3 (55.10) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x954c0000 - 0x95ac6fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95b20000 - 0x95df0fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95e40000 - 0x95eadfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x95f00000 - 0x95f20fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x968d0000 - 0x969b2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x96a20000 - 0x96ae2fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x96b40000 - 0x96b6efff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x96bf0000 - 0x96c7ffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96cb0000 - 0x96d9efff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x96e80000 - 0x96e90fff com.apple.vecLib 3.0.2 (vecLib 3.0.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97510000 - 0x97518fff libbsm.dylib /usr/lib/libbsm.dylib
niro
Postby Jerm » Sun Nov 07, 2004 12:15 pm
The crash log is useless. However I was able to reproduce this problem and it has been fixed.
