Sagan Technology Metro • View topic - problem recalling user settings for effects
Postby sigmasix » Fri Nov 21, 2003 8:07 pm
does anyone else out there have a problem recalling user settings for plug ins? i save them in the default VST folder like i'm prompted too but i can never recall them... sometimes recalling actually crashes metro.
sigmasix
Postby Jerm » Fri Nov 21, 2003 8:09 pm
Do you mean presets? Which plug-in(s)?
Postby Jerm » Fri Nov 21, 2003 11:20 pm
Yes. User created VST Presets are broken and will be fixed in version 6.1.0.5. They do save okay but do not load. Sorry about that.
Postby sigmasix » Sat Nov 22, 2003 11:06 am
thanks for the info.. i will be awaiting the update!
sigmasix
