Sagan Technology Metro • View topic - record displacement when recording audio
Postby mark scheel » Wed Mar 21, 2007 10:56 am
1
i noticed a random displacement when doing the following
rerecord a click track and switch to record mode while metro
is already running. the recorded material seems to be off
in timing sometimes.
2 i cant get punch out to work the sequencer stops everytime
i use the punch mode no matter what option in choose in record dialog.
any ideas?
thank you
mark scheel
mark scheel
Postby Jerm » Wed Mar 21, 2007 1:40 pm
1. We are looking into this but we need more information. Are you using any plug-ins? What audio hardware are you using?
2. It stops at the punch out time or before it even records? I just tried it with version 6.3.8.5, just released, and it did stop at the punch out time but the audio was punched in fine.
Postby mark scheel » Thu Mar 22, 2007 4:17 am
same result here
in 6.3.8.5 rerecording a click on my mac powerbook g4 worked just fine
haven t tried with my motu 828 yet.
punch out point still stops the sequencer althoug the 'stop at punch out time' item is unchecked.
greetings
mark scheel
mark scheel
Postby mark scheel » Thu Mar 22, 2007 7:31 am
sorry i have to correct myself
rerecording a click is still off timing when i use
the record button manually to trigger recording while
the sequencer is running.
i m using the newest version of the program
greetings
mark scheel
mark scheel
Postby Jerm » Thu Mar 22, 2007 1:54 pm
Hello Mark,
mark scheel wrote:rerecording a click is still off timing when i use
Thank you for finding this bug. It has now been fixed. On-the-fly recording has never been sample accurate. Unfortunately this fix, making it sample accurate, requires too many changes to make it into Metro until version 6.4. I don't want to introduce new problems in 6.3 as the feature set of that product is now frozen.
