Sagan Technology Metro • View topic - Bringing 4.0 and 5.0 projects into 6.
Postby rickchaff » Tue Mar 18, 2003 6:56 am
What is the quickest/fastest/safest way to bring 4.0 and 5.0 projects into 6.0.
Thanks!
rickchaff
Postby Jerm » Tue Mar 18, 2003 1:00 pm
Rick,
If the projects are on the same machine, open them. If they are on different machines then the best way is to save the old project as a Metro Bundle file. This will include all audio referenced by the file and when the bundle file is re-opened all audio files are recreated. It is a good idea to make backups in the form of bundle files as well.
Postby rickchaff » Tue Mar 18, 2003 8:51 pm
Thanks Jeremy.
rickchaff
Metro 6 and Metro 5 on same machine
Postby rickchaff » Sat Mar 22, 2003 10:04 am
I've recently upgraded to 6 and I suppose I should have removed all of 5 before doing so.
- If I launch a 5 or 6 Metro Doc from the document Icon I get an error -39 message.
- If I try to open a Metro 5 doc from within 6 I get and error 2 message.
Should I remove 5 completly and then reinstall 6?
Rick
rickchaff
-39 error when opening pre-Metro 6 files or bundles.
Postby Jerm » Mon Dec 01, 2003 1:59 pm
I have recently seen a -39 error when trying to open some old bundle files. It is apparently a bug since Metro 6 :( an artifact from updating the compiler. It is now fixed in 6.1.0.5. 8)
error-39
Postby rickchaff » Tue Dec 09, 2003 10:22 pm
Thanks Jeremy!
rickchaff
