| Hint: Using the Spray Note Tool’s Slow setting is great for entering single note events with slightly randomizedvelocities, durations, and start times. This can be particularly useful formanually entering Drum Strikes in the Drums display. In fact, when using this method,it’s possible to place Drum Strikes whose start times fall between a specifiedclock range, even if Note Edit Quantize mode is enabled. |
