Drum Fills
Drum Fills
Postby GSpro » Wed Jan 22, 2014 6:21 pm
Hello Jeremy,
How about a "drum fills" feature implemented into URE?
Something like - breaks/fills with durations ranging from 1/4 to 4/4 and anything in between. Maybe with "Fills/Breaks Generator" next to the "Pattern Generator?"
Thank you,
Adriano
GSpro
Re: Drum Fills
Postby Jerm » Wed Jan 22, 2014 8:15 pm
Already there you just have to know how to set it up.
Go to a drum view and select the time you want the fill to be. Then select the drum names by clicking and shift-clicking. URE will do fills. :mrgreen:
Re: Drum Fills
Postby GSpro » Wed Jan 22, 2014 8:43 pm
That's what happens when I'm off for long periods of time. I tend to forget where some things are or how they're accomplished. :mrgreen:
All good though. I'm actually trying some things (only METRO is able to provide) using the URE in different ways and on different instruments, to get some ideas. I never thought of going through having "Composer's Block," but apparently seems to be very common.
Have written scores, scored to picture, orchestrated music for songwriters and now this.
Anyway, thank you Jeremy
Adriano
GSpro
Users browsing this forum: No registered users and 33 guests
