Mute notes
Mute notes
Postby fastlanephil » Wed Aug 05, 2015 6:29 pm
Hello Jeremy,
Maybe there is a way to select and mute notes in the Graphic Editor that I don't see but if not it might be a nice feature. What I do now is either push the notes up or down out of the range of the instrument or pull them forward in time. I could see using a feature like this when arranging but not always. It's just an idea. Probably not worth spending too much time on.
Phil Lovgren
Re: Mute notes
Postby Jerm » Fri Aug 07, 2015 10:06 am
I would cut the selection and then select a new track and paste it into the new track. Then mute, archive or assign the port to 'off' on the new track.
Re: Mute notes
Postby fastlanephil » Sun Aug 09, 2015 12:47 am
Yes, that is another option depending on what you're doing. Thanks.
Muting notes might make sense if you wanted to cut just a few notes to a track measure for a listen but I guess it wouldn't be much of a time saver.
Re: Mute notes
Postby Jerm » Sun Aug 09, 2015 6:25 pm
Personally I think it would be confusing, unless the notes were drastically highlighted in some way to make it obvious that the notes are currently muted.
Re: Mute notes
Postby fastlanephil » Mon Aug 10, 2015 12:38 am
Jerm wrote:Personally I think it would be confusing, unless the notes were drastically highlighted in some way to make it obvious that the notes are currently muted.
I read some news about DP9 adding this feature awhile back and I've found a video showing it with the new DP9 features on YouTube. It looks like the DP9 green piano roll notes become pale when muted. I did another search for DP9 user responses about it and they look to be not too excited about it.
Users browsing this forum: No registered users and 22 guests
