soundfontsynth
soundfontsynth
Postby almapercus » Wed Aug 09, 2006 8:43 pm
Robert
almapercus
Postby Scoot » Thu Aug 10, 2006 1:42 am
By the description, it allows you to use soundfonts.
With OSX, Metro allows you to use them already.
In the plugins window is an effect called - DLSMusicDevice which you can put a soundfont into to use, instead of QT instruments.
Re: soundfontsynth
Postby w » Mon Aug 14, 2006 5:27 pm
almapercus wrote:Any user of this software synth?
http://andydrabble.users.btopenworld.co ... einfo.html
Yes, I use that software synth.
w
Postby almapercus » Mon Aug 14, 2006 6:43 pm
SoundFontSynth works in metro but there is a noticeable delay while playing live, which I don't feel when using it into garage band.
I can't find how to add sf to DLSMusicDevice, the only choice appearing is the QT synth...
Robert
almapercus
Postby Jerm » Mon Aug 14, 2006 8:39 pm
To fix the delay you can configure the audio packet size to be 384 or less in the digital audio device options dialog.
Postby Scoot » Tue Aug 15, 2006 1:41 am
almapercus wrote:I can't find how to add sf to DLSMusicDevice, the only choice appearing is the QT synth...
If you have a midi track you can place a DLSMusicDevice in as an effect.
In the effects/synths window that the DLSMusicDevice is on, is a large button (just left of the reverb). If you click it you can then find and install a SF from here.
Postby almapercus » Tue Aug 15, 2006 8:33 am
Yeah, thanks a lot guys!
Robert
almapercus
