chapter tracks
Topics related to Video
chapter tracks
Postby jlvalero » Fri Feb 23, 2007 2:45 pm
is it possible to export markers to a quicktime file and retrieve them as inside a chapter track? I don't think so, but it would be superb!
Currently it would be great to be able to simply copy the marker window content or to export it as a file...
thanks
jean-louis
jlvalero
Postby Jerm » Fri Feb 23, 2007 4:49 pm
It is currently not possible to export markers to a movie but it should work to a MIDI file.
Postby jlvalero » Fri Feb 23, 2007 5:14 pm
Jerm wrote:... it should work to a MIDI file.
Thanks for the answer! but I've just tried it and don't retrieve markers with quicktime player. What is the problem?
jlvalero
Postby Jerm » Sat Feb 24, 2007 1:58 am
I am not sure what you are looking for. How would quicktime player retrieve markers anyway?
Podcast
Postby jlvalero » Sat Feb 24, 2007 3:32 am
Jerm,
I'd like to obtain with Metro what is inherent to GarageBand: Podcast or VideoCast export. As a composer for movies it's easy for me, with that format, to show what I have done: the film maker has only to have QuickTime on his computer for exploring my music on his film thanks to chapters function.
If it is not in your intend, the fact to be able to copy as text what is inside the markers window would be a good advancement: I'd be able to make my own cooking.
Of course I could use GarageBand but I don't feel comfortable with polygamy
:oops: :roll: :oops:
jlvalero
Postby jlvalero » Sat Feb 24, 2007 10:17 am
In fact here is the text file format I need Metro to export from its markers:
{QTtext}{font:Geneva}{plain}{size:12}{textColor: 65535, 65535, 65535}{backColor: 0, 0, 0}{justify:center}{timeScale:25}{width:160}{height:48}{timeStamps:absolute}{language:1}{textEncoding:0}
[00:00:00.00]
{textBox: 0, 0, 50, 160}Prologue
[00:00:30.03]
{textBox: 0, 0, 50, 160}P02 I
[00:00:54.12]
{textBox: 0, 0, 50, 160}P03 Il
[00:01:15.00]
{textBox: 0, 0, 50, 160}P04
[00:01:34.12]
{textBox: 0, 0, 50, 160}P05
[00:01:47.10]
{textBox: 0, 0, 50, 160}P06 111
[00:01:59.24]
{textBox: 0, 0, 50, 160}P07 IV
[00:02:26.02]
{textBox: 0, 0, 50, 160}p08V
[00:02:42.10]
{textBox: 0, 0, 50, 160}P09
[00:03:19.17]
{textBox: 0, 0, 50, 160}P09 Vi
[00:03:23.24]
{textBox: 0, 0, 50, 160}p10
[00:03:32.12]
{textBox: 0, 0, 50, 160}P11
[00:03:43.21]
{textBox: 0, 0, 50, 160}p12 VII
[00:03:55.11]
{textBox: 0, 0, 50, 160}p13
[00:04:02.23]
etc...
the markers were:
Then I import that text into QuickTime player Pro , I copy the result and paste it inside the movie. With Command+J I transform the text track into Chapter. Now I can use the chapter function inside my movie.
jlvalero
Postby Jerm » Sat Feb 24, 2007 10:54 am
To copy the markers in text format or to have an export as text from the markers window would not be very difficult to add. Please add a feature request in this forum if that is your intention.
Postby jlvalero » Sat Feb 24, 2007 10:57 am
thanks! If you're fearless could you transform the last ":" with "." ?
I'm afraid to be somewhere abusive...
:oops:
jlvalero
Postby Jerm » Sat Feb 24, 2007 11:27 am
In Metro the last SMPTE field is a bit field that ranges from 0 to 80. Is that what QT is looking for or is it a percent?
Postby jlvalero » Sat Feb 24, 2007 11:52 am
Jerm wrote:In Metro the last SMPTE field is a bit field that ranges from 0 to 80. Is that what QT is looking for or is it a percent?
I only know that we must specify the number of frames/second with
{timeScale:25} or {timeScale:30} etc.
So, in [00:04:02.23] ".23" is the number of frames, not the bit field. QuickTime dances to a different drummer and uses a period and not a colon to represent the frames.
jlvalero
Postby Jerm » Sat Feb 24, 2007 11:57 am
Sorry. I was wrong. Metro does not display the bit field. The last item is the frame number.
Return to Video
Users browsing this forum: No registered users and 23 guests
