MIDI tracks
MIDI tracks
Postby juanchamo » Sun Jan 25, 2004 8:16 am
Hi,
If I'm not wrong, when I import a MIDI file into the Metro SE demo, all the file tracks go into one track.
That's fine for playback, but now, I can't mute a MIDI instrument because all of them are on the same track.
Am I right so far?
How can I import a MIDI file, so that each instrument goes into a different track so that I can edit them individually?
Juan
juanchamo
Re: MIDI tracks
Postby Jerm » Sun Jan 25, 2004 12:31 pm
juanchamo wrote: when I import a MIDI file into the Metro SE demo, all the file tracks go into one track.
No. Only if the MIDI file is of type 0. Type 1 MIDI files are already separated.
juanchamo wrote: That's fine for playback, but now, I can't mute a MIDI instrument because all of them are on the same track.
The trick is to use expand by channel. This will separate out all of the tracks based on MIDI channel. You can then mute as you please.
TIP: Set the output port from the tracks window for the first track by using edit port in the outputs column BEFORE importing a MIDI file to have all the tracks automatically be assigned to that port.
Postby juanchamo » Mon Jan 26, 2004 9:15 am
Thanks!
Your trick worked beautifully.
Juan
juanchamo
Re: MIDI tracks
Postby Scoot » Tue Jan 27, 2004 7:20 am
Jerm wrote:TIP: Set the output port from the tracks window for the first track by using edit port in the outputs column BEFORE importing a MIDI file to have all the tracks automatically be assigned to that port.
Is there a quick way to change the ports once open to multiple tracks?
Say I import a midi file taking up the first 6 tracks and I want all the tracks from 7 onward to become audio, can you hold down a key combination and adjust one track, and get all the others to change as well?
Users browsing this forum: No registered users and 49 guests
