plug-in sound player with 16 channels
Postby françois » Thu Jul 12, 2012 2:03 pm
Hello,
could someone remember me how to obtain differents sounds in the same track ?
I set " plug-in" is multimbral ( BS-16, Halion..... ) but if I select different channels and different sounds, it's always the sound of the channel 1 that is playing, impossible to set the sound of the channel 2....
Could you tell me how to do please ?
Re: plug-in sound player with 16 channels
Postby Jerm » Thu Jul 12, 2012 9:49 pm
You need to select the port. In the graphic editor (or tracks window)'s output field, select the popup and select 'port'. In your case it would be something like "Port:Halion". When selected like that the track can send 16 different channels to the plug-in. Note that there is no direct mixer channel assigned to the track in that case.
Postby françois » Fri Jul 13, 2012 12:03 pm
ok, it work fine.
Thank You !!!
Users browsing this forum: No registered users and 43 guests
