Note(s) Selection
Note(s) Selection
Postby GSpro » Sun Nov 23, 2008 1:38 pm
Hello forum,
How do I select specific notes within a specific range in one shot without double-clicking on each one for deletion in the Graphic Editor?
Thank you
GSpro
Postby Jerm » Mon Nov 24, 2008 6:26 pm
You can either use the forceps tool in the graphic editor or you can control-click (right-click) into the graphic editor. Once you have the pitches you want to delete selected you can use select-all to make the selection across the whole track for that pitch range.
Alternatively you could use the extract dialog.
Or you can command-click each note.
Am I understanding your question correctly?
Postby GSpro » Tue Nov 25, 2008 7:03 am
Yes Sir,
The extract dialog does the trick.
Thank you
GSpro
Users browsing this forum: No registered users and 35 guests
