when I play in midi I get an anunwanted note
Postby arenson » Fri Apr 27, 2007 6:29 am
Hi
I recall I saw the answer to this...when I play the keyboard, I hear, along with the notes/instruments I am playing, a ping ping ping.
It is not there on playback, but it is annoying. I can set them manually back via the keyboard/
Ca you remind where where i turn this off?
I am connecting my P250 keyboard to the computer.
arenson
Postby Scoot » Sun Apr 29, 2007 12:13 am
metronome turned on in the transport window????
Metronome...no
Postby arenson » Sun Apr 29, 2007 9:37 pm
Ok, too many variables. Metronome is not set. And now I do not get that extra tone. that is good. But can't set instruments correctly now.
If I load an existing file I made from internet it sort of works... As I use it so infrequently, I forget what I did last time.
So I start from scratch. But something is not right....
Tracing the steps+¥*
MIDI SETUP
Open Metro. Launch Midi Setup. Line between P250 keyboard and NEW EXTERNAL Device. So I est setup: click New External Device) and get sound ok
Record from, receive sync from P250Port 1 Send sync to New external device, P250, Port 2.
OUTPUTS
8 midi starting with 1 (new external device)
8 audio starting with 9 (Firepod)
Replace existing (Did not check Make outputs reflect MIDI Setup
I TRY IT
Ok...I can enter all and they sound ok, in piano.
(I hear a random single note though when not doing anything that is creepy.)
So I add ins file
PROGRAM NAMES
For port NEW EXTERNAL DEVICE
Assign P20 Bank 112
OPEN P250 ins file
OK
But this doesn't allow me to control the names.
Need to go back to square one and do systemcatically as I use so infrequently I forget.
arenson
