Metro 6.3.1 pre-release
Postby Jerm » Thu Jun 16, 2005 6:35 pm
Upgrades from 6.2 are free. All new purchases include access to this version. There is an upgrade price of $29.99 to upgrade any flavor of Metro from 6.x to 6.3.
Download it here:
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to Metro/Metro SE version 6.3!
IMPORTANT: This pre-release (Metro and Metro SE) still works under OS 9 but we are no longer providing Tech support for OS 9.
New to this version:
• New: Drag and Drop has been vastly improved so that you can drag a MIDI or audio file to a precise time and track in either the graphic editor or Tracks editor. This makes working with plug-ins like Stylus RMX and iDrum much less complicated. This will work for both type 0 and type 1 MIDI files but type 1 MIDI files must contain only a single track. If multiple files are dragged or a type 1 MIDI file with more than 1 track is dragged the destination will be either a new track or a new section.
Drag and drop to the graphic editor in this way is automatically quantized to the nearest bar as indicated in the upper left of the graphic editor.
• New: Stationery documents are back. Metro detects any document with an extension of .msd as a Metro Stationery Document. This will allow users to load in the document but the document will not set the current filename. This means that save will bring up a 'save as' dialog preventing the original document from being implicitly overwritten.
• New: The jukebox will not scroll to the active playing song if playback scrolling is in edit mode.
• New: Standard bank select MIDI controllers (0 and 32) are recognized when passed through MIDI thru and presented in the graphic editor.
• New: In the Rhythm Explorer pattern algorithms there is a 13% chance that a given pattern will search for a drum track and groove quantize to it. If the option key is held when generating patterns the chance rises to 100%.
• New: Auto detection of soft-synth bank and patch changes (for plug-ins like Absynth 3). If a patch is changed within a plug-in's user interface, Metro does a better job by noticing it and keeping the current program name display in sync.
• New: Multiple instances of plug-ins are now more aptly named. For example, the second Absynth 3 instance will be named Absynth 3-2 instead of Absynth 4.
• Fixed: Better support for real time editing and audio tracks especially when the edit changes the track length.
• Fixed: The Jukebox was erroneously converting little endian 24 bit .WAV audio files.
• Fixed: the playback time sent to aux buss plug-in effects was incorrect for the first two buffers sent. In most cases this would have no adverse affects.
• Fixed: Metro detects MIDI and KAR files better than in previous versions.
• Fixed: Highlighting of the tracks window and graphic editor during drags would sometimes not work correctly.
• Fixed: the 'beat and tempo' procedure called by Audio Unit plug-ins now provides greater accuracy.
• Fixed: pasting past the end of a playing track could sometimes cause weird results.
• Fixed: Expanding subsections did not create new instances of track insert plug-ins like it should have.
• Fixed: Get info in the jukebox window correctly shows the file information even if the file is a high-resolution audio file written by QuickTIme 7.
• Fixed: Changing patches in background when programs were mapping to plug-in presets was previously not working correctly.
• Fixed: Copying subsections not always working correctly.
• Fixed: In some cases the graphic editor view would be wrong after a paste.
• Fixed: Undo was in some cases created a blank track.
• Fixed: Dragging numbers up and down did not work well when there was a large range between the minimum and maximum allowable entries.
• Fixed: The velocity setting of groove and track quantize has been vastly improved in the case when there are multiple notes in the source.
• Fixed: Track names derived from file names now automatically remove the extension.
• Fixed: crash was occurring on clear of an audio track if all regions were selected and the track was looped
• Fixed: crash was occurring if rewire was enabled but the rewire slave did not start up properly.
• Fixed: if loading of a rewire panel application failed, Metro would completely tear down rewire.
• Fixed: Metro sample converter was not converting 32 bit (non-float) files correctly in some cases.
• Fixed: the Metronome was not clicking in some cases after a cue loop occurred or in some cases if there were looped tracks.
• Fixed: Double clicking in the tracks window would bring up the beginning of the current selection in the graphic editor instead of the time that the mouse was clicked.
• Fixed: Setting the bar length of a playing-looped-non-MIDI-track to 0 could of resulted in a crash.
• Fixed: Clearing the map program numbers to presets from the 'EFX MIDI filter and options' dialog accessed from the effects/synths window would sometimes not dispose of the generated program name lists.
• Fixed: In some cases VST synths would not show up in graphic editor popup.
• Fixed: The annoying change port dialog only pops up once now if the document contains stale core audio device outputs.
• Fixed: Transposing a track containing both an audio and a MIDI view now does the right thing.
• Fixed: Labels around parameter knobs in the effects window were overwriting each other for certain AU's without editors.
• Fixed: Certain audio operations were being disabled erroneously if the track was an Audio + MIDI track.
• Fixed: Miscellaneous other minor bug fixes.
Users browsing this forum: No registered users and 34 guests
