Using the Rhythm ExplorerUse the following procedure to add rhythmic and harmonic treatments to yousongs using the Rhythm Explorer:-  Select the notes you want to affect in the current track.
 -  Expand the Transport window, and enable Cue Looping. That way, when you audition each Rhythm Explorer pattern, you can hear thenew pattern repeated many times in a more complete rhythmic context.
 -  Choose Rhythm Explorer from the Windows menu.
 -  Click the None button to make sure that no algorithms are selected. (You don't always have todo this, but it's good to start off with simple patterns and move up to morecomplex ones.)
 -  Use the pop-up menu to select an algorithm to change the rhythm of the currentselection.
 -  In the Variability field, click one of the radio buttons to change thevariability of the selected algorithms. For example, click the Low button to generate a few patterns that are only slightly different from eachother.
 -  Click the Generate button to generate new patterns from the algorithm(s) youselected. Metro generates 8 colored rectangles, representing 8 differentpatterns derived from the algorithms and variability that you selected.
 -  Click a rectangle. The pattern it represents starts playing (and looping, if Cue Looping is on). You can audition the rest of the current patterns by clickingdifferent rectangles. To compare the patterns with the original selection, click the Original icon, in the center of the rectangles.
 -  Now generate a new set of patterns, by clicking the Generate button. If you like the previous group of patterns better, click the Use Lastbutton.
  The color of each rectangle matches the algorithm that you select. If you'vechosen several algorithms, and you choose higher variability settings, eachrectangle may take on several colors to show that it uses several algorithms atonce.When you find a pattern you like, click Apply to alter the selected data.Now you can save your file, complete with the alterations the Rhythm Explorermade. See Also:Rhythm Explorer Rhythm Explorer Algorithms  |
