Sagan Technology Metro Forum Index Sagan Technology Metro
The place to interact with other Metro users.
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Warning: Quicktime 7.4
Post new topic   Reply to topic    Sagan Technology Metro Forum Index -> Announcements
View previous topic :: View next topic
Author Message
PostPosted: Thu Jan 24, 2008 3:48 pm    Post subject: Warning: Quicktime 7.4 Reply with quote
Quicktime 7.4 will break Metro the 'save' functionality of all versons of Metro prior to 6.4.1.1 resulting in an error -54 message.
Do not install Quicktime 7.4 if you want to continue to use Metro, Metro LX or Metro SE before 6.4.1.1.
Metro 6.4.1.1 fixes this problem allowing save to work. However this problem is within Quicktime 7.4 and thus could introduce other problems.
Perhaps Quicktime 7.4.1 will fix these issues.
Edit: Indeed, Apple's release of Quicktime 7.4.1 fixes this issue!
Back to top
View user's profile Send private message [ Hidden ] Visit poster's website
PostPosted: Thu Jan 24, 2008 9:22 pm    Post subject: Too Late For Me Reply with quote
So That's what's going on!
I was able to work around it with a metro file I had created previously to installing QT 7.4 but new files are now blanks.
Luckily I still have my old iMac G5 DAW setup to work with for now. Smile
Phil
Back to top
PostPosted: Thu Jan 24, 2008 9:52 pm    Post subject: Reply with quote
Another thing to note is that the file is actually saved (at least in my testing) but the file type is left as a quicktime movie when it is really a Metro document. It is possible to recover any saved files by changing their file type to 'BYSQ'.
If you have developer tools installed you can use the terminal program. Otherwise you need a utility program.
How to change a file's type and creator code using the terminal utility's command line?
Use the tool “/Developer/Tools/SetFile”. You need to install the Developers tools CD that came with OS X at least 10.1. Type “man SetFile” to see its doc but generally you can use this format
/Developer/Tools/SetFile -t BYSQ filename
where instead of filename simply drag the file to the terminal. Be very careful to only try this on a backup copy to be sure you know what you are doing.
Back to top
PostPosted: Thu Jan 24, 2008 11:08 pm    Post subject: Reply with quote
Thanks for the information Jerm.
I found an old file editing utility called FileType that seems to work.
Once you have it converted to a Metro file you can SAVE changes but to save as you will have to make a copy of the file in the finder.
This seems to work for me.
FileType asks for a donation so if I have to use it long I'll send them a few if they are still active.
Phil
Back to top
PostPosted: Fri Jan 25, 2008 12:25 am    Post subject: Reply with quote
Well I have a fix coming within the next couple of days so no need to worry.
Back to top
PostPosted: Sat Jan 26, 2008 1:30 pm    Post subject: Reply with quote
Here is an article that describes how to revert back to Quicktime 7.3.x. This is necessary for users who cannot upgrade to Metro 6.4.x for whatever reason.
Metro is not the only product affected by this Quicktime 7.4 bug.
Back to top
PostPosted: Wed Jan 30, 2008 4:50 am    Post subject: Reply with quote
Typical!
Jerm's here to fix Apple's mistakes! Wink
Back to top
View user's profile Send private message [ Hidden ] Visit poster's website AIM Address
PostPosted: Fri Feb 08, 2008 3:25 am    Post subject: Apple Fixes BUG! Reply with quote
Good news! Apple has fixed the bug in QT 7.4 with the 7.4.1 update. This means that old version of Metro work properly with new versions of the OS as long as QT 7.4 is not involved.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Sagan Technology Metro Forum Index -> Announcements All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
