Sagan Technology Metro • View topic - Double speed audio playback. bug?
Postby Scoot » Tue May 20, 2003 4:04 pm
If I import an mp3, metro asks to save the aiff of it as a temp file.
With the settings mono, 16 bit and 22khz the track comes into track #1.
With the record "R" on, the track plays at double speed.
With it off, it plays normal.
Why should it play double?
Is metro assuming I want to do modifications to the track at 44khz?
I can bring the track in at 44 to start with of course but it is already a large file. (At 44khz it's 597MB!)
Postby Jerm » Tue May 20, 2003 4:46 pm
Investigating....
Postby Jerm » Tue May 20, 2003 5:27 pm
I cannot repeat this problem. It always plays normal for me. Have you tried different MP3's?
Postby Scoot » Tue May 20, 2003 7:15 pm
dam!
I thought ok if I can do this all the time and you can't it must be a switch.
And it was.
Turn on "software audio thru".
Postby Jerm » Tue May 20, 2003 7:39 pm
Ok, this is not a bug. This is the result of play back and record at different sample rates with software audio thru on.
