Sagan Technology Metro • View topic - macOS Sierra
macOS Sierra
macOS Sierra
Postby w » Sun Oct 16, 2016 8:19 pm
Is Metro LX 7 ( mac version ) good to go with macOS Sierra ?
w
Re: macOS Sierra
Postby Jerm » Mon Oct 17, 2016 3:01 pm
Have not tried it yet here.
Re: macOS Sierra
Postby w » Mon Oct 17, 2016 7:18 pm
OK, I'l try it out and see what happens.
w
Re: macOS Sierra
Postby Jerm » Mon Oct 17, 2016 11:36 pm
Thanks and please let me know how it goes.
Re: macOS Sierra
Postby w » Thu Nov 03, 2016 11:41 am
Well: yes and no , mostly no.
It launches and imports audio or midi however when it comes to makes adjustments to the” set up. “ ( font’s for example ) then it crashes. And as usually the crash happens before saving all the work on the file.
w
Re: macOS Sierra
Postby Jerm » Thu Nov 03, 2016 6:24 pm
Thanks for the report. I will take a look at this as soon as we get a Sierra compatible mac in house.
Re: macOS Sierra
Postby Jerm » Fri Nov 04, 2016 3:22 pm
Can you email me the crash log please?
Re: macOS Sierra
Postby w » Fri Nov 04, 2016 7:26 pm
OK, there on their way via email to info_at_sagantech.biz Fri, Nov 4, 2016
w
Re: macOS Sierra
Postby Jerm » Fri Nov 04, 2016 8:47 pm
Hello Walter,
Please do NOT put real email addresses in forum posts. Spammers scan forums to create email lists!
Re: macOS Sierra
Postby Jerm » Wed Nov 09, 2016 5:01 pm
Looks like this is an Apple bug in the font panel, introduced in Sierra and supposedly fixed in MacOS 10.12.2.
I will have verification if this is indeed true later today.
Re: macOS Sierra
Postby w » Tue Mar 14, 2017 11:15 pm
Jerm wrote:Looks like this is an Apple bug in the font panel, introduced in Sierra and supposedly fixed in MacOS 10.12.2.
Is this still an issue with the macOS Sierra 10.12.3 ?
w
Re: macOS Sierra
Postby Jerm » Tue Mar 14, 2017 11:46 pm
I don't think this issue exists in 10.12.3. I know Apple fixed it. There is also an issue with missing widgets (close and zoom buttons) on the transport window. Apple also fixed this but I think it is In 10.12.4
Re: macOS Sierra
Postby w » Wed Mar 15, 2017 8:58 am
So Metro should not have any more problems as previously encountered regarding setups and fonts ?
Hopefully yes because i have nearly stopped using Metro since i was tired of those crashes.
Tried using Metro the other day and encountered trouble with applying a plug-in to an imported audio file. Will try to replicate that issue and if it still occurs will send you a report. Meanwhile here is a screen shot.
myScreenShot 2017-03-14 at 10.29.56 PM.png (43.13 KiB) Viewed 7955 times
w
Re: macOS Sierra
Postby Jerm » Wed Mar 15, 2017 12:40 pm
There is an explanation for this. Please tell me the exact steps to reproduce.
