Sagan Technology Metro • View topic - Drum Kits
Drum Kits
Drum Kits
Postby usula boy » Wed Jan 21, 2015 8:53 pm
There is a long list of drum kits that show up in the graphic editor pop up window just above the "New Drum" pop up. Can I access those kits and if so how? As of now I can only access the ones on my MIDI devise.
Thanks.
In the mean time I'll keep reading through the manual.
usula boy
Re: Drum Kits
Postby Jerm » Thu Jan 22, 2015 1:41 am
The drum kits you have found are simply mappings. They map drum notes to MIDI pitches. If you have the particular drum set then it would make sense to use them.
Re: Drum Kits
Postby usula boy » Thu Jan 22, 2015 10:47 am
Got it. Thanks
usula boy
