Sagan Technology Metro • View topic - Automation (Show used parameter only)
Postby Lytz1 » Sat Jul 12, 2014 8:44 am
Hello Jeremy,
while working on the first projects, I noticed some more things,
that might be (hopefully) quick but useful implementations.
What might be a huge timesaver would be the ability to
show used (means: recorded) automation only.
For guys like me, that automate a lot, this would be very useful indeed,
so that I do not need to search through pages of parameters
(especially on soft synths) to find the one with the small (*) in front of 'em.
Especially when automating a couple of plugin parameters and editing them back and forth,
the search time for the ones that were actually recorded adds up pretty substantially.
(i.e. Yesterday I was doing stuff with a couple of soft synths and after automating
I basically spent more time searching for stuff than I actually spend time making music.. : )
Re: Automation (Show used parameter only)
Postby Jerm » Sat Jul 12, 2014 4:52 pm
Yes. This is a very good idea.
Something like "show only used parameters" as the first item in the popup menu?
Postby Lytz1 » Sat Jul 12, 2014 6:19 pm
Jerm wrote:Yes. This is a very good idea.
Yes, exactly. That would be the shortest way to access it and would tie in there pretty well.
Postby Jerm » Sat Jul 12, 2014 9:37 pm
I'll see what I can do.
Postby Jerm » Sun Jul 13, 2014 3:04 am
This feature has been implemented and will be in the next release.
Postby Lytz1 » Sun Jul 13, 2014 7:19 am
Excellent.
Thanks J,
