Sagan Technology Metro • View topic - Audiophile USB, ASIO drivers and Metro 6
Postby MediaUnion » Tue May 06, 2003 1:55 am
Hey,
I just upgraded to the M-Audio Audiophile USB interface from the iMic. (a great project studio interface for under $200, 24(32?)bit, 109db range, but I digress....)
I'm using Driver version 1.5.0f15 (the most recent) which states it loads the ASIO drivers during install. When navigate to Metro>Setup>Digital Audio...the only choice I get is the "Direct Support" radio button. Is anyone using the AP USB with ASIO drivers in Metro 6?
Thanks...
MediaUnion
Postby Jerm » Tue May 06, 2003 1:33 pm
If you are using OS X, ASIO does not exist. Under OS 9, you need to place the ASIO driver or an alias to it in Metro's ASIO folder.
Thanks!
Postby MediaUnion » Tue May 06, 2003 9:01 pm
Hey Jerm,
I'm using OS X.
Thanks for the help!
Kevin
MediaUnion
Users browsing this forum: No registered users and 15 guests
