Hints:
1.Those functions need software support, and you must make the right setup in the software before you can use those buttons properly. 2.If you press one of the 6 buttons after the keyboard is powered on, the keyboard will start sending MTC(MIDI timing clock). To stop sending MTC, press "Reset" compound, or just turn off then turn on the keyboard
Jerm wrote:I sent an email to CME so we'll see if they respond.
Are all those sysex's from record? or do you get a different one for each button press. Click on the sysex and see if the data is the same or different. If they are different I can support it in the future by adding a sysex event.
the UF6 has stopped produced for a long time, we don’t have any in stock right now
But we can provide you some information below, maybe it will help you.
KEYBOARD MARKER MIDI OUT USB OUT(Drive v1.04)
TOP TOP F2 00 00 B0 73 7F(CC#115)
REW REW F2 nn rr B0 74 7F(CC#116)
FF FF F2 nn rr B0 75 7F(CC#117)
REC REC F0 7F 00 06 06 F7,F0 7F 00 06 07 F7 F2 nn rr B0 72 7F(CC#114)
STOP STOP FC B0 76 7F(CC#118)
PLAY PLAY FA B0 77 7F(CC#119)
Users browsing this forum: Google [Bot] and 4 guests
