Sagan Technology Metro • View topic - MIDI FIle import
MIDI FIle import
MIDI FIle import
Postby Markuc » Wed Sep 28, 2011 5:01 pm
Hello, when I import MIDI FIle, the Notation looks like this :
MIDI File import.gif (36.06 KiB) Viewed 20702 times
how to edit this ? (Metro for Windows)
Thank You
Markuc
Re: MIDI FIle import
Postby Jerm » Thu Sep 29, 2011 2:18 pm
Can you email me the MIDI file?
Postby Markuc » Sun Oct 02, 2011 8:30 am
Yes, of course. What is your mail adress ? I didn´t find it here :)
Markuc
Postby Jerm » Sun Oct 02, 2011 1:32 pm
you can email it to info at sagantech.biz
Postby Jerm » Sun Oct 02, 2011 3:15 pm
This is what I get:
Perhaps you did not install properly. When you install be sure you select the correct system drive so that the font goes to the correct place.
Postby Markuc » Sun Oct 02, 2011 4:00 pm
My install folder :
Metro path.jpg (110.77 KiB) Viewed 20686 times
Markuc
Postby Markuc » Sun Oct 02, 2011 4:10 pm
... I tried new instal in other "Program files" folder (for 64bit applications) with same result ...
Metro path 2.jpg (133.65 KiB) Viewed 20686 times
Markuc
Postby Jerm » Sun Oct 02, 2011 6:28 pm
We don't usually do tech support for the demo but the problem is not in your 'programs' folder. It is in your 'fonts' folder.
You need to have the 'Aloisen new' or 'Aloisen regular' font installed.
Postby Markuc » Mon Oct 03, 2011 2:50 pm
OK, no support for demo version, I understand.
Markuc
