Sagan Technology Metro • View topic - Check for Updates...
Postby w » Wed Jun 01, 2011 10:35 am
Could you program a "Check for Updates..." in Metro LX and other Metro applications ?
w
Postby Jerm » Wed Jun 01, 2011 12:00 pm
The about box tells you unobtrusively that there is a new version available if there is one.
Burtu
Postby acciccathen » Wed Jun 22, 2011 10:28 am
wtf? I do not believe :)
acciccathen
Re: Burtu
Postby w » Wed Jun 22, 2011 11:18 am
acciccathen wrote:wtf? I do not believe :)
Exactly.
I sure don't see that
w
Re: Check for Updates...
Postby Jerm » Wed Jun 22, 2011 1:09 pm
If you are running a version of Metro prior to 6.5 and you go to the about box you will see something like:
New Version Available: 6.5
Postby w » Wed Jun 22, 2011 3:35 pm
OK, just for greater certainty, if you issue an update to Metro LX 6.5 the about box will tell me at that time that there is an update ?
w
Postby Jerm » Wed Jun 22, 2011 7:00 pm
Well yes. If I update all of the correct files correctly :mrgreen:
Postby w » Sun Jun 26, 2011 4:52 pm
OK i now see how it works by installing an old version.
w
