Hello Tommy,
Well, your search was correct. Metro is the best sequencer for Mac. I have no relations of any kind with Saganthech or, Jeremy (the developer) just a very happy and satisfied user.
Metro has been around for a very long time. Yes, the user base is not as high compared to L-o-g-i-c, D-i-g-i-t-a-l P-e-r-f-o-r-m-e-r and a few others and it is very strange indeed.
#1 thing you'll get here, that you wont get anywhere else is support. No joke!
#2 If you find a bug in the program, Jeremy is all over it and most of the time it is fixed within a day or two. Other companies, you'd have to wait and 99.99% of the time, is still not fixed.
#3 Do you have a feature request? Just place it in the appropriate forum.
#4 Application stability? Way up-there.
#5 No Bloated-ware. Metro has a very small footprint after installation. Can't remember correctly but, I think is around 6 megabytes, Jeremy can correct me on this. Extremely light on CPU and memory. You'd only put a hit on this depending on the amount of VI and plugins you use.
#6 You can score to video if you want, then, export.
#7 MIDI? Second to none!
#8 Plug-ins? AU and VST fully supported. Try that with the two DAW I mentioned above. I can't recall, Jeremy will correct me on this too, I think VST was updated to the latest version.
These are just some of the things that come to mind at this moment. Have not had coffee yet (no pun intended).
Yes, Metro does not make coffee nor, pancakes, but, it does put food on the table, thou. This is all I do, Tommy.
Have you downloaded the demo? That's something you don't get from others either. I think it quits after 30 minutes and you just have to relaunch the app.
Another way to get the best possible answer, would be for you to tell us what do you want the DAW to do and how you will be using it.
Again, I hope some of the info I posted are of some help. If not, please ask.
GSPro
