Sagan Technology Metro • View topic - halion sonic
halion sonic
Postby GSpro » Mon Aug 16, 2010 4:01 pm
No hurry and take your time.
you still have my email address, right?
GSpro
Postby françois » Mon Aug 16, 2010 4:03 pm
yeah...! adriano.... always....
send me a midi with the sounds of your choice, and I will change with halion sounds.
Postby GSpro » Mon Aug 16, 2010 4:05 pm
If you still have some of the ones I sent you, just modify one of them. You'd have to bounce it to aiff or MP3 though. I don't have Halion Sonic. I just like to hear what it sounds like.
Thank you, my friend
GSpro
Postby françois » Mon Aug 16, 2010 4:07 pm
ok I'll send you.
Postby Jerm » Mon Aug 16, 2010 5:04 pm
GSpro wrote:That's one thing I can say about Metro. The program just runs and runs and runs. There are times when I'm on a project for 4-5 days, sometime 7 or 8 without ever quitting the application and I do tend to forget to save and never an issue.
I personally think, it's one of the most stable DAW on the market.
Thanks.
However, you should always remember to, not only save, but to also do a backup. You never know when lightning will strike or when your hard drive will simply die and having a backup can avert that kind of disaster.
Not to mention that for each plug-in you run you are adding quite a few new variables to the equation.
Postby françois » Mon Aug 16, 2010 5:13 pm
GSpro wrote:If you still have some of the ones I sent you, just modify one of them. You'd have to bounce it to aiff or MP3 though. I don't have Halion Sonic. I just like to hear what it sounds like.
the song is done, but...
I don' t how to bounce....
Postby françois » Mon Aug 16, 2010 5:18 pm
I found.... File..../.... Mix
Postby GSpro » Mon Aug 16, 2010 8:53 pm
Jerm wrote:Thanks.
Hello Sir,
Yes! You are absolutely right. It's just that after a long day, at the end I start to draw blank so to speak. When I do come back to the project, I do perform a Save and do make frequent backups to external HDs. Lighting I was never really worried about. Everything I run in the studio is on uninterrupted power supplies. Each piece of equipment has its own. I have lost electric a few times, but it has not interfered with the midi or audio end of it. It does give me plenty of time to save and shudown.
You are also correct about when adding plug-ins and that's where I think Metro has a lot of strength too. I understand exactly what you mean, but personally, I have never had an issue. I have pushed Metro several times and has never once quit, locked-up, chocked, stutter or anything. You name it and I probably have already done it. I think also, it has to do with how clean the system is. I am picky. Every couple of months or so, I perform a clean install and you can tell because I have to re-authorize Metro. :) Sorry about that. :) OK, I'm too picky.
You keep up the good work, because you have gotten a customer for life.
Thanks for reading,
Adriano
GSpro
Postby Jerm » Mon Aug 16, 2010 10:49 pm
Thank you Adriano! I wish more people realized what you are saying.
Jeremy
Previous
