Sagan Technology Metro • View topic - Doesn't Work! :shock:
Postby clarinetwill » Mon May 10, 2010 7:45 am
I am interesting in buying the se version, so downloaded the demo. The package does not install properly. When i click on the icon it bounces once then fails to open. I'm on mac os 10.3.9 imac g3.
clarinetwill
Postby GSpro » Mon May 10, 2010 9:55 am
Hello clarinetwill,
From the system requirements on this link, you will need a G4 processor
http://www.sagantech.biz/metro/help/read_me.shtml
GSpro
Postby clarinetwill » Mon May 10, 2010 12:22 pm
Is there a G3 version about? The processor and ram I have isn't bad for a g3 ~ 750Mhz and 1Gb RAM
clarinetwill
Postby Jerm » Mon May 10, 2010 12:23 pm
The demo version of SE should work. Are you sure you downloaded the SE version?
Are you saying the installer does not launch or the application does not launch?
Postby clarinetwill » Mon May 10, 2010 1:32 pm
I launch the installer, it gets to 75% and then says package not installed, try again. It does install the folder and all the extras in the apps folder but the app itself won't open.
It was the SE version yeah.
Thanks for the support. Hope I can get it to work...
clarinetwill
Postby Jerm » Mon May 10, 2010 1:49 pm
I just tried it from my MacBook Pro and it downloaded, installed and launched fine.
Try this.
Go to hardDrive:library:receipts and drag 'Metro SE Demo Installer.pkg' to the trash (where 'hardrive' is the name of your hard drive).
Then try to reinstall.
Postby clarinetwill » Mon May 10, 2010 2:46 pm
Still no joy i'm afraid. Just to check, what is the package in th __MacOs folder? Is it different to the one in the main folder? I'll try it in my intel iMac Alu tomorrow. Thanks for the superb support.
clarinetwill
Postby Jerm » Mon May 10, 2010 3:14 pm
I will try it on a G3 later and let you know if I find anything. There is little ore I can try without more information.
