Sagan Technology Metro • View topic - Is there a log of special effects applied to a song/file ?
Postby w » Sun Apr 18, 2010 9:00 am
I needed to do more work on an "old" project song. How do determine what special audio effects i had previously applied?
w
Postby w » Mon Apr 19, 2010 8:41 pm
I take the silence as a NO way of determining what effects were applied to a sound track.[/i]
w
Postby Jerm » Tue Apr 20, 2010 11:12 am
I am not sure I understand your question.
If you go to the effects window and go through each track and aux buss you can see the effects that are applied. Also you can right-click on the title bar of each track in the graphic editor.
All effect edit windows will appear in the windows menu.
If you mean, applied directly to the audio, then there is no way unless you kept track yourself.
Postby w » Tue Apr 20, 2010 9:41 pm
That's what i was looking for Jerm.
w
